Sausage Making
Totally depends how much the meat is, I use high qaulity meat so not really compared to supermarket.
Casings cost next to nothing, hen depends what ingriedents you use.
How do you get on with the Andrew James mincer? I was happy with the mincing but could hack it for stuffing. I moved to a barrel piston type stuffer which I found much easier to use.
ps your sausages look good how did they taste.
Yet again tasted good but texture is still far to grainy and doesn't bind.
I'm ee ping the meat ice cold when grinding/stuffing so I don't think it's that.
The one thing I did see on dinners, drive ins and dives is that after grinding they stuck it in to a food mixer with a paddle and used that for about 10minutes.
Has anyone ever got sausages with a good texture what's the secret?
They look very nice. Damn shame they didn't turn out how you wanted them to though :/
I've found the texture of homemade sausages somewhat hit and miss. The best ones I made were using lamb shoulder (technique for freezing/etc was exactly the same as you use). I used very little in the way of breadcrumbs in that one. I think I most likely used zero breadcrumbs and lots of green/regular onion. I definitely made sure everything onion/garlic-related was extremely finely chopped and due to my lack of knowledge at the time I'm pretty sure I didn't put much in the way of breadcrumbs in the mix. If I did it was actual minced fresh bread rather than dry breadcrumbs.
I think the above is worth experimenting with though definitely not worth taking as gospel in terms of obtaining decent results.
I very much doubt it's lack of fat, there's still huge amounts of fat left.
Also same texture on the other sausages which had added pork back fat in them.
I really do think its something to do with the grinding.
I also know salt massively affects binding, but it had a fair bit of that in it.
I'll have to give the mixer method a try.
I'm not sure that mixing it more would make the texture better.
I think part of the issue is that commercial sausages have 'conditioned' us to expect things to be homogeneous and when we make things at home it has more of a texture. What we think of as grittiness isn't actually a bad thing. Perhaps the dried onion thing isn't suitable I guess.
I think randomshenans' point about fat is actually a good one. I know you're (Glaucus) not one to scrimp on fat in a recipe but I do think that more is..well, more... in the sausage situation. The best sausages I ever made were made from a mixture of lamb leg and pork shoulder (mostly the fat on the shoulder). They are the only ones I ever made that didn't suffer from the slightly gritty texture you have described.
