HI there
We have being seeing a lot of customers buying high-end power supplies with their 1080Ti's, we suspect this is because they are doing system upgrades or ensuring any chance of coil whine is an absolute minimum due to the fact the 1080Ti's generally boost to over 2000MHz core which is some serious crazy frequencies which can cause some electrical noise on lesser quality power supplies.
As such we have decided to put together a bundle on which OcUK firmly believes to be the best (fastest) 1080Ti on the market with the best warranty (5yr) - The Zotac 1080Ti AMP Extreme which retails at £829.99 by itself.
We then decided to pick one of the very best power supplies on the market that will run incredibly efficiently with this graphics card (not ideal for SLI if OC) and also have a superb warranty, 7yr, this is of course the Seasonic 80+ Platinum 760W.
If you were buying these items separately they would cost you £1000, however when you buy as a bundle you save yourself £100, in short that is like getting the Zotac AMP Extreme for £730 or the Power supply for £70, absolute bargains.
The bad news is we only have 100 power supplies available for this bundle and we have over 200 Zotac Extremes due to arrive next week.
As such it makes perfect sense to not buy the graphics card, but to buy this bundle as the additional cost is just £70 and you get a superb PSU that would be right at home in your rig or on the ebay site for sale at more than the £70 it essentially cost you or great if your putting together another system for a friend or family etc.
Zotac GeForce GTX 1080Ti AMP Extreme Spectre RGB VGA Card & Seasonic 760W 80+ Platinum PSU Bundle - £100 OFF! @ £899.99 inc VAT https://www.overclockers.co.uk/Zota...ic-760W-80-Platinum-PSU-Bundle-BU-000-ZT.html
Buy the Zotac GeForce GTX 1080Ti AMP Extreme Spectre RGB and the Seasonic P Series 760W 80+ Platinum Power Supply together and save £100!
Only £899.99 inc VAT.
ORDER NOW
Remember guys only 100 bundles available, do not miss out, its an ace deal!![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
![](https://img.overclockers.co.uk/media/image/thumbnail/BU000ZT_165103_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/BU000ZT_165105_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/BU000ZT_165106_285x255.jpg)
ORDER NOW
