Hi,
We have been checking out our b-grade section and it seems there are a lot of products where people can grab a real bargain as most products just have a damaged box.
All hard drives are products that have been either returned from manufacturer repaired or returned as unwanted after a few minutes of use from customers. All hard drives are in fully working order and formatted of data.
hard drives and ssd's here
coolers are a little different than hard drives in that they will all have the mounting parts for the cooler but could have no box/manual or it could just be that the box is damaged. the coolers will have all parts required for you to install and use.
coolers here
fans here
laptops are mainly unwanted returns and the customer has just changed there mind and decided that they have spent to much money and need it for other things. they all come factory reset and have the power adaptors to use them. the boxes maybe damaged but they are all functional as intended.
laptops here
water cooling clearance is a mixture of both new parts and b-grade. if the item is b-grade it will say in the title. take a look and you maybe able to combine parts in order to get your pc cool this summer. b-grade items are as normal they will have the parts to mount and fit but may have open packaging or damaged packaging.
water cooling here
a few items listed below any questions i will be happy to help. low quantities on all items in clearance.
**B Grade** ASUS ROG GL702VS NVIDIA GTX 1070 8GB, 17.3" FHD 120Hz G-Sync, i7-7700HQ Gaming Laptop @ £1,449.95 inc VAT
GL702VS-BA085T, 17.3" G-Sync Anti Glare , Intel Core I7 7700HQ, Nvidia GTX 1070 8GB GDDR5, 256GB SSD, 1TB (SATA) 7200 RPM HDD, 24GB DDR4, Windows 10 (64bit), 2yr Warranty
Only £1,449.95 inc VAT.
ORDER NOW
**B Grade** HP OMEN 15-ax009na NVIDIA GTX 950 2GB GDDR5 15.6" IPS, Intel i5-6300HQ Gaming Laptop @ £499.99 inc VAT
15-ax009na, 15.6" LED 1920x1080, i5-6300HQ, NVIDIA GTX 950 2GB GDDR5, 1TB 7200RPM HDD, 8GB 2133MHz DDR4, Windows 10 Home (64-Bit), 1yr Warranty
Only £499.99 inc VAT.
ORDER NOW
**B Grade** MSI GE72MVR NVIDIA GTX 1070 8GB GDDR5, 17.3 FHD 120Hz, Intel i7 7700HQ Gaming Laptop @ £1,299.98 inc VAT
MSI GE72MVR Apache Pro 064, Intel Core I7 7700HQ, Nvidia GTX 1070 8GB GDDR5, 17.3 FHD 120Hz, 256GB NVMe SSD, 1TB HDD, 16GB 2400MHz DDR4, Windows 10 Home (64-Bit), 2yr Warranty
Only £1,299.98 inc VAT.
ORDER NOW
**B Grade** Raijintek Orcus RGB AIO Water Cooling Unit - 120mm @ £49.99 inc VAT
0R100080, All in one cooler, RGB Lighiting, Intel Socket Support 775 / 1150 / 1155 / 1156 / 1366 / 2011 / 2066, AMD Socket Support: AM2(+) / AM3(+) / AM4 / FM2(+)
Only £49.99 inc VAT.
ORDER NOW
**B Grade** be quiet! Silent Loop Superior Liquid CPU Cooler - 240mm @ £99.95 inc VAT
Socket compatibility: Intel®: LGA 775 / 1150 / 1151 / 1155 / 1156 / 1366 / 2011(-3) Square ILM, AMD: AM2(+) / AM3(+) / FM1 / FM2(+) , 3 Year Warranty
Only £99.95 inc VAT.
ORDER NOW
**B Grade** Fractal Design Celsius S24 240mm All in One Water Cooler @ £79.99 inc VAT
FD-WCU-CELSIUS-S24-BK, AIO Cooler, 240mm, Compatibility, Intel ® Socket: 1150/ 1151/ 1155/ 1156/ 1366/ 2011/ 2011-v3 / 2066,
AMD: FM1/ FM2/ FM2+/ AM2/ AM2+/ AM3/ AM3+/ AM4, 5 Year Warranty
Only £79.99 inc VAT.
ORDER NOW
**B Grade** Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM010) @ £29.99 inc VAT
Part of the Compute Guardian Range, 1TB Capacity, 3.5 inch, SATA 6Gb/s Interface, 7200RPM Spin Speed, 64MB Cache, 2 Year Warranty
Only £29.99 inc VAT.
ORDER NOW
**B Grade** Samsung 960 EVO Polaris 250GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive @ £59.99 inc VAT
MZ-V6E250BW, 250B Samsung 960 EVO, M.2 (22x80) PCIe 3.0 (x4) NVMe SSD, V-NAND, Read 3200MB/s, Write 1500MB/s, 300k/300k IOPS, 3yr Warranty.
Only £59.99 inc VAT.
ORDER NOW
**B Grade** WD Red Pro 6TB 7200rpm SATA 6Gb/s 128MB Cache HDD OEM (WD6002FFWX) @ £189.95 inc VAT
6TB Capacity, SATA 6GB/s Interface, IntellliPower 7200RPM Spin Speed, 128MB Cache, 5 Year Warranty
Only £189.95 inc VAT.
ORDER NOW
**B Grade** Seagate BarraCuda 2TB 7200RPM SATA 6Gb/s 64 (HD-385-SE) @ £44.99 inc VAT
Only £44.99 inc VAT.
ORDER NOW
**B Grade** EK Water Blocks A120 Fluid Gaming Performance Water Cooling Kit @ £129.95 inc VAT
Fluid Gaming, 120mm Water Cooling Kit, CPU Loop, Aluminium, Light Weight, High Performance, Compatible with Intel LGA-115X/ LGA-2011(-3)/ LGA-2066/ AM3 and AM4, 2 Year Warranty
Only £129.95 inc VAT.
ORDER NOW
**B Grade** XSPC RayStorm Twin D5 AX360 WaterCooling Kit @ £249.95 inc VAT
The RayStorm Chrome Twin D5 AX360 kit is the most powerful 360 kit XSPC have ever made.
Only £249.95 inc VAT.
ORDER NOW
All Clearance Items Available Here
coolers here
fans here
laptops here
water cooling here
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
