- 8 Jan 2007
Hi,
Currently using a Sound Blaster Z & AE Aego M's, which have finally given out after around 8 years). I'm looking at just a decent set of 2.1's & the Kratos S5 seem to get good reviews.
I've done some research and see that a lot of speakers now have USB & their own Sound Card - sounds cool & makes sense given it's outside of the internal PC system.
I guess my question would be; for sound quality / overall experience, would I be better:
1. Remove my Soundcard & connect the Kratos by USB & use the Kratos software
2. Keep the soundcard & connect the Kratos by 3.5mm and use the existing software
Open to either option, as I'm sure a lot's changed since I last purchased these AE Aego M's.
Thanks Guys!
Thanks Guys!
