SBS 2008 ipv6 & exchange issues
22 Feb 2007
UK
Had a lot of issues with this one server.
Cusatomer wanted a new user setup, it fails creating the mailbox as theres an issue between AD and Exchange.
Just recently they haven't been receiving e-mails. There are no returned errors, not delivery recepits returned, they can send, outlook connects fine, even owa doesn't sho new mail, and nothing in the queues or tracking to say they received them.
MS have asked to try loads of stuff, I think it boils down to an IPV6 issue. I try and run the Fix my Network, two things show.
--IPV6 The netwirk card does not have a static IPV6 address, this can cause issues.
--Router can't be configured.
Router isn't the issues, its the ipv6, if I let it run it won't stop, juts runs and runs and runs.
How can I try and force it, how to I know what to manually assign it? If I remove card, reboot, reinstall will it fix it running Fix my network again?
I'm on the verge of re-building it if I can't fix it this morning. :(
ipconfig /all
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\BDDATA>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : EUST-SR-01
Primary Dns Suffix . . . . . . . : business.local
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : business.local
Ethernet adapter Euston-Place-LAN:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : HP NC373i Multifunction Gigabit Server Ad
apter #2
Physical Address. . . . . . . . . : 00-23-7D-A7-9D-D8
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::106a:d4d9:4add:8ece%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.200.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.200.1
DHCPv6 IAID . . . . . . . . . . . : 184558461
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-10-72-47-F3-00-23-7D-A7-DD-DC
DNS Servers . . . . . . . . . . . : 192.168.200.2
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 8:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : isatap.{DC261DAF-7F04-4C73-B8DA-9DF531B2A
C91}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
C:\Users\BDDATA>
externally telnet to the primary MX showing on internet dns (use nslookup)
have a chat with it and send an email to an internal address...
something like
ehlo
rcpt to:[email protected]
mail from:[email protected]
data
the above my be wrong google it...
try the same thing internally from the lan...
the server may tell you whats wrong when you talk to it or oyu may find the problem is not as complex as it appears and your MX records are just wrong...
edscdk - you hit the nail on the head. domain expired on the 18th May so mx record is incorrect. My colleague is sure he checked it though, I wonder if it just hadn't updated so it looked correct at the time.
Rob - ipv6 was disabled at some point, it is now enabled, its setup as dhcp, not static. imo because a few people have looked at it the servers a bit of a mess and needs re-building. Nice clean install, SP1, all the rollups etc.
Thanks guys, e-mail problem solved.
