- 20 Aug 2007
- Solihull
Hey guys, bit of a problem, I don't know if you remember a post I made in this forum a while back regarding reinstalling an SBS server. Either way, I have this freshly installed SBS server, it's all setup on it's own, connected to router and ready to start having clients assigned to it.
However - when I try and http://connect, it times out - Using a client PC I can ping the servers IP on the router which is 192.168.10.38 but I can't "ping connect"
I have tried manually setting the DNS server address and DNS suffix but I still get the same issue, I'm not sure if it's an issue with services not running or if it's a problem with the router getting in the way.
Currently the router is acting as DHCP server but I know it is possible to have this server acting as a local domain with the router assigning IP addresses as DHCP.
I'm starting to get confused though, could anyone help?
I'm happy to set up a teamviewer session if anyone is kind enough? (not a data security risk as no data is stored locally, all cloud based
Thanks in advanced, Jamie
)Thanks in advanced, Jamie
