SBS2011 stuck in loop
Ish
Ish
11 Jan 2006
West Midlands
Hi
At the community centre I volunteer at the users were complaining that the shared files and logging on was very very slow.
I couldn't RDP in to the server so I looked at the physical machine and I said "FAILURE CONFIGURING WINDOWS UPDATES...REVERTING CHANGES...DO NOT TURN OFF YOUR COMPUTER.
I checked the server about 8 hours later and it said the same thing so I manually rebooted it. Whether I try and boot to safe mode or normal the same message as above comes up.
What are my options?
I think the above problem is not the main problem.
The server finally rebooted in to SBS2011 but is running very slow. I ran the Dell diagnostics and it showed up some errors:-
Error code 4400:1780 SMART failure prediction threshold exceeded
Error code 4400:011B block xxxx medium error (this came up about 10 times for different blocks)
Error 4400:247E Drive self test failed with (0x04) The self test completed with an unknown error
On all the above errors it also gives a reference SATA_0-000_DISK_S/N:xxxxxxxxxxxx
The server is a Dell T310 with the following:-
2TB SATA 7.2k 3.5" HD Hot Plug
PERC H200 RAID Controller, For Hot Plug HDD Chassis
C18 Hot-Swap - R1 for SAS 6iR/PERC 6i/H200/H700, Exactly 2
Can I take the faulty drive out as a short term fix?
If I get a new drive do I just put it in and will the server rebuild the raid 1 array automatically?
I just found out the server had an extended 3 year Dell prosupport warranty taken out in 2014 after the initial 3 year warranty expired.
Will this cover the hard drive or will they charge for the cost of the drive?
looking at it, it looks like technical support and hardware replacement
"Onsite parts and labor response options* including next business day or four-hour mission critical"
may have to pay for the hardware
It says in the wording "Onsite parts", meaning it's all covered. That's the point of a warranty.
