Scandisk Ultra 2 - Missing GB
25 Dec 2008
Hi Guys,
Just bought a scandisk ultra 2 960GB drive as a second drive, installed the drive, was detected by BIOS.
Started windows and ran windows disk manager to allocate the drive.
Windows only sees the full capacity of the drive as 890 GB - which i have now allocated.
What happened to the other 70GB? Is it normal for SSD's to not have the full advertised storage capacity - like mobile phones?
Anyone else encountered this before?
Thanks
All storage mediums 'lie' about the size, they quote raw unformatted sizes which are unusable, you must format it to use it. It is particularly annoying with SSD though as its basically a fancy non volatile ram system.
It's simply a case that manufacturers use Gigabytes (10^9 bytes or 1,000,000,000 bytes) whereas Windows uses Gibibytes (2^30 bytes or 1,073,741,824 bytes).
It's a total myth that you lose the space when formatting.
This. Manufacturers use "decimal" Gigabytes (powers of 10), whereas in reality all computer systems work in binary (powers of 2).
Hey there, nukemdukem.
Basically @Borealis and @BlackAle said it best. You could check out this article for more info on the subject: Drive displays a smaller capacity than the indicated size on the drive label. There's a table with different capacities as well.
If you'd like to calculate them yourself you could simply divide by 1024 three times and you'll get the approximate binary capacity in GB. E.g. in your case 960 000 000 000 bytes / 1024 = 937 500 500 / 1024 = 915 527 / 1024 = 894.07GB. So basically your SSD should be ~894GB.
Cheers!
Boogieman_WD
This. you only 'lose' about 70Mb to formatting.
