Permabanned
- 28 Dec 2009
- london
Has anyone deployed windows 7 via sccm operating system deployment?
There are a lot of guides on the internet and it is looks like a very unnecessarily convoluted process.
http://blogs.technet.com/b/gborger/...a-windows-7-capture-image-using-sccm-osd.aspx
In the past I have just created a windows 7 installation with all the applications and used sysprep and scripting to automate the whole process. For deployment i have just used manual or pxe boot. (using clonezilla)
With the sccm method it definitely appears to be less customizable because it appears that you just specify a basic windows 7 reference image (which is the normal windows 7 disk) then you use sccm to add it to the domain and deploy applications within it. This seems very restricted in terms of advanced application deployment that requires a lot of registry changes.
Microsoft have also gone out of their way to use strange terminology like reference images, boot images, task sequences. Seems a bit gimmicky.
Has anyone actually used this method to deploy advanced enterprise images?
It appears to me that SCCM OSD is basically just installing a basic windows image with no customizations and then depends on SCCM afterwards to actually install applications and customizations. is that correct ?
