Hi all,
I am in the market to upgrade my headphones from my HyperX Clouds as they are on their way out (strap being dodgy) and thought i might see if i can upgrade my sound as a whole somewhat.
My current setup is a Soundblaster Z, with my Clouds plugged in as well as my Aego M speakers. I can switch between the two using the Z series control panel.
I am considering getting the gsx 1000 or the modi/magni 2 ubers and maybe some dt770s or the like to get some good sound. Ideally i would like to have both speakers and headphones plugged in and be switchable via a hardware button.
My usages are probably 75% gaming (fps), 20% movies, 5% music.
Could anyone give me some advice on the best hardware to buy/good headphones for comfort etc. I will just buy a separate mic like a modmic etc.
Trying to keep the budget to sub £500 but there is wiggle room if it makes a significant difference.
Cheers
Cheers
