Scraping Sound from Rear Wheel in Corolla (05)
21 Jul 2004
Harrow, UK
Yesterday I noticed a scraping sound coming from the rear right wheel of my Toyota Corolla (05).
It occurs at all speeds and even when the brakes are not depressed.
I have a feeling that the brake pads are worn as the ABS seems to be kicking in at times when it shouldn't, but I wouldn't have thought that that would cause the scraping sound I am hearing.
Should do if your alloy has big enough gaps. Just point the camera in and try and snap some pictures of the top of the calliper. A picture of the complete disc will also help.
Behind the brake disc there is another disc looking piece of metal. That is the brake dust protector to stop damage to the disc. If you jack the car up and spin the wheels you will be able to tell which wheel it is and check to see if the protector has come loose. Happened on my EX's mk5 Golf.
Pad overhanging the unused part of the disc seems odd, the pad guide looks a bit bent and twisted to me too? Bit hard to see from the pics, but there could well be an issue there.
^^ as above. That's probably the source of your scraping sound. Looks like the pad has slipped out of place. That's symptomatic of something having caused that though.
It's hard to be certain of anything from those pictures, but your noise could be caused by something as simple as a small stone being trapped behind backplate ("dust shield")
We're talking brakes though, so get it checked out by a professional at the earliest opportunity.
