So I spent my weekend removing scratches and stone chips with a repair pack I got from paints4u. Generally very happy with the results, although applying wet n dry to my car took some guts innitially I can tell you.
Unfortunately before I could finish polishing the light scratch marks from the wet n dry the polishing drill head thingy I had purchased came off and got a load of grit stuck to it
So I cant use it now.
I am gonna spend this week painting up layers on a particularly nasty gowdge (sp?) out of the rear plastic bumper (was on there when I bought the car dont know how it occured) I also need to get some finer WnD paper (3000).
Can anyone recommend a powered tool to do the polishing? I found this page:
http://www.autoexpress.co.uk/product_test/58139/best_buffers.html
And they are recommending something nice and cheap £14.99 - but will it do the chop I am looking for?
Cheers for any help.
So I cant use it now.I am gonna spend this week painting up layers on a particularly nasty gowdge (sp?) out of the rear plastic bumper (was on there when I bought the car dont know how it occured) I also need to get some finer WnD paper (3000).
