- 11 Jan 2012
- Bedfordshire
If you've got fluorescent tubes at work that's probably part of the problem.
Every light in the office consists of 1 fluorescent tube (Instead of the 2 they take), does that often cause issues?
16:9? No. That's an aspect ratio ideal for watching TV and movies on, not doing office work on. At the least a 16:10 screen is needed and not a cheap TN panel one either which a lot of IT departments will buy because they're cheap.
Doesn't have to be 75Hz either, 60Hz is just fine but screens should be properly configured with optimal brightness and colour settings in relation to the office lighting they're used in to avoid fatigue or worse.
In relation to drinking water... It does in fact seem to be that it has gotten a LOT worse since I've been drinking less water. I used to sit right next to the cooler so drank it all the time, and then I moved half way across the room and drank it less. I now sit at the completely opposite side of the room to the cooler and drink water much much less. I'll bear that in mind.
I'm 19, I best not be a knackered old goat!
Yeah, staring at a screen for 8 hours a day at work and then up to another 7 when I get home. However when I'm at home my eyes don't hurt in the slightest.
Optician said my eyes are perfect, both vision wise and health wise. Nothing to worry about at all.
You can get Nikon lenses (without prescription if not needed) that are designed to filter light in a certain way to reduce VDU fatigue. Might be worth looking into those?
I can get a glimpse of all 11 lights in the office from where I'm sitting. And then also a 27" monitor which is blasting a green circle on a white background facing directly at me, as well as light coming from outside.
Do you think light is the issue here combined with the crappy aspect ratio of the monitors?
