Just put together a new system & reinstalled XP (no service packs yet). I have a single SATA drive (Samsung Spinpoint Sata II) but for some reason it's properties describe it as an SCSI drive. Is this normal?
-this is the 1st time I have used a sata drive & I'm a wee bit confused
I made up a floppy disk with the SATA drivers on it and pressed F6 when prompted. The floppy drive lit up for a brief second & then went off (no grinding/juddering noises like when the floppy drive usually operates) so I'm doubtful if the windows install actually accessed the drivers.
I also installed the drivers again (just to make sure lol) once windows was up & running -this time I used the installation cd instead of the floppy disk. Still shows as SCSI though.
Have I cocked up somewhere?
