Scsi Raid config question
23 Mar 2005
I'm about to reformat and start again (again, again, again...) And was thinking about the way I've got my arrays set up. I'm using the Perc 4e/DC / Lsi Megaraid 320 2e which has 2 channels, 15 'drives' each.
I'll be setting up a 3 Disc array, a 4 disk array, and a 2 Disk array (all Raid 0). I'll be setting up on 64kb, writeback, adaptive read. Any changes to those?
Big question: for the 4 Disk array: (4xSeagate 72 Gb 15k4 drives) would it be faster with all 4 on one channel or 2 one each?
Also - I've got 2xSeagate 72Gb 15k3 drives - would it be best to raid them alone, or add them to the 4 disk array above?
Cheers
At a guess I'd split the 4 disk array across the channels - there's a 320Mb/s limit on each cable and 4 x 15k4 could get close to that.
I'd keep the 15K3s separate too, a 6 disk RAID0 array is a bit big for my liking and having mismatched drives isn't going to give you optimal performance.
Thanks for that - I was hoping this thread would catch your eye :D
Since I've lost windows I might do a bit of benching and spend some time trying different options to see what gives the best performance. I double checked the drives and the 2 'other' are definitely 15k3's so I'll keep them seperate. So far I have to say I haven't been blown away by this controller - it's fast (150mb/s ish) but certainly nowhere near the magic 320 - hopefully the 4 disks will start to get closer (theoretical max read of 80Mb/s per drive... :D ) But reading around I'm yet to find anyone with more that about 160ish... seems odd.
If I can't get past the 200 mark I think I'll just chuck the whole lot and see if I can get one of those nice Adaptec cards and some of those new Seagate sata's ;)
I saw in the HDD benchmark thread that you got some awesome scores out of yours (even with raid 5 :eek: ) but that was with 8 drives - what kind of performance you you expect with a Raid 0 of 4x7200.10's?
Yeah, but it's 8 x T7K250s, it feels like the case is going to shake itself apart when it's reading heavily ;)
I've got a pair of 7200.10s in RAID0 which aren't perfect (and I can't be ****ed messing about with them any more) but I still get 115Mb/s average. I have a feeling that there are some 4 disk RAID0 benches in the benchmark thread.
matja said:
on a 15k drive? I'd be surprised if it went that slow...
From the Seagate site:
  • 15k4: Up to 96-MB/s sustained transfer rate
  • 15k5: Up to 125-MB/s sustained transfer rate
The older 15k3's were 70-80ish, bearing in mind that's an 'up to' number - you'd be lucky... ;)
I'd be very happy if I got 80 out of my 15k4's (in fact that's about what I got when I benched one on it's own!)
Anyway - just rebuilding the rig now - will split the arrays across the 2 channels and see what it can do!
Well - this is turning into a complete goat! I've got the system back up and running any everything is behaving nicely:
c: 3x18Gb 15k.3 in Raid 5 - Windows
d: 4x72Gb 15k.4 in Raid 0 - Speedy drive
e: 1x36Gb 15k.4 in Raid 0 - Programmes...
(Had to mothball the 2x72Gb 15k.3's as I'm out of connectors :rolleyes: )
Ran the Benchies:
c: 120mb/s - about right I would have though
e: 79mb/s - again - about what I expected
d: 130mb/s - :mad: Not happy at all - this is all turning into a farce (especially as my 3x18Gb's in Raid 0 were giving me 150mb/s +)
I've tried all the obvious things and am working some of the more obscure features. I was a little intrigued by one of the windows options to set the minimum 'data size' on partitioning - thought that might help if it matched the stripe size - but it didn't.
Any ideas what the problem could be - these should be nearly twice that speed?!?!
Hmmm... I've changed the stripe size to 128kb and the scores have jumped back to the 150mb/s mark - odd as I always thought smaller stripes gave faster bench results - Still not very impressed - was getting that out of a couple of 15k.3's so this should be considerably faster - the peak speed it topping out at around 200mb/s so there is definitely hope - the graph is completely flat (ie. no tail off towards the end of the drives) so it's not the drives but the adapter/bus that's the bottleneck - just can't seem to find a way around it - should be capable of much faster speeds - I'll post up a coupld of HDTach shots a bit later. Any ideas welcome :confused:
