Hey,
I have just installed my scythe ninja. However I have only just noticed that the cable from the fan is 3pin and the cpu fan on the motherboard is 4 pin. Now my power supply has a cable for extra fans in which i can plug the 3 pin into and then the cable into a 4 pin directly to the power supply. Is this ok or is it essental that i plug the fan into the cpu cooler thing on the motherboard.
Thanks.
Thanks.
Coretemp puts it at about 45 which I think is about right. I'd reccomend using that
