Scythe Ninja - horizontal mouting, issues?
24 Jul 2003
Looking at the Ninja for a future Conroe build but the motherboard will be mounted horizontally (like in a desktop case) so that the fins in the Ninja will also be horizontal rather than vertical as normal in a tower case.
I'll be using it with the 120mm fan and, additionally, a 120mm exhaust behind it.
Anyone see any issues with this?
Will still wort ok m8,as long as you have a fan mounted on the cooler,why not go for the Scythe Miné Quiet Heatpipe CPU Cooler already has a fan installed in the middle of the cooler.
I believe that the heatpipes work better with the setup you're using as the liquid inside can rise and fall more easily , thus carrying the heat away from the cpu more effectively.
