Hi all,
I have a Bosch hammer drill and was wondering, I have loads of standard drill bits from an old non-hammer drill, is there any way these can be used in my drill?
I assume something like this would work?
http://shop.parkerbs.com/makita-p-33788-keyless-chuck--sds-adaptor-1007-p.asp
And if so, will I be able to use the drill on hammer mode with the adapter or not?
I have a feeling I looked into this before and it depended on the adapter, usually it could only be used in standard drill mode?
Can anyone confirm please?
Thanks
EDIT: Because something like this is quite cheap, but doesn't say if it can be used on hammer action or not.
http://www.amazon.co.uk/Am-Tech-2-inch-Keyless-Chuck-Adapter/dp/B000VODBBU
Whereas this (below) looks similar and states no hammer action
http://www.screwfix.com/p/sds-plus-chuck-adaptor/93301
Thanks
