Sea water = brown or very dark blue
without seeing the picture im not sure, but i can give you a suggestion.
Select the sea, but using the lasso tool or a quick layer mask.
change brightness slightly higher
change colour balance to blue
adjust accordingly
Or alternatively change the colour in hue/saturation to a close colour to blue, brighten, then adjust colour balance to blue.
Post picture and il have a go.
If your using Photoshop CS, go to Image > Adjustments > Replace Colour.
Then select a bit of the brown sea and then selecta replacement colour from the pallette.
lost the damn original , so this is a scan.
colours are now washed too :(
very unlikely with that picture im afraid mate. It would be easier to just stick the 2 people on a new background, still they look to blown out and bright.
looks a lot better already, damn its a **** i cant find the original, mind u that was taken at some crap beach i took the nephews too, i do prefer greece :D
thx a lot people
