Seagate 7200.10 400GB question
21 Jul 2005
London
Does anyone know if 400GB flavor also has the same noise problems as 300GBs?
I would assume that they use the same motor/working mechanism?
i have two 400gb seagates, one is gen 9 and the other is gen 10, the gen 10 is sata and gen 9 is ide, i would say out of the two the gen 9 ide is quitest but the gen 10 is still a quiet harddrive unless you try and write or rad to much data at once..
Hope this was helpfull ;)
Cheers for the replies.
Think I'm going to take the plunge and order one from a competitor for £85.
Merry Xmas.
I've had two 400GB 7200.10s for a couple of months. There's a little bit of noise when they're accessing (RAID 1 so it's both of them each time) but nothing otherwise.
