We highly recommend the IronWolf for your NAS needs. BarraCuda is our current desktop PC/gaming lineup, IronWolf is our current NAS lineup, and SkyHawk is our current surveillance drive lineup.Here is a chart to delves a little into the different drive types:
Drive Types Chart
When you see different drive types like surveillance, NAS, and desktop, this means they were engineered with different uses in mind, and usually have different firmware on the drives for those uses as well. Surveillance drives like SkyHawk are optimized for write operations majority of the time, for example, writing to a surveillance DVR system 90% of the time and playback (reading) the other 10%. Different drive types also have different workload ratings. Nas drives such as IronWolf can be similar to SkyHawk in that they also have a 24/7 rating, but are is more balanced in terms of read/write usage and has firmware designed with multiple users, cloud storage, vibration, and NAS enclosure applications in mind.
You'll find that NAS drives sometimes have longer warranties than other types of drives. The standard IronWolf has a 3 year warranty and the IronWolf Pro has a 5 year warranty (and bumps the TB per year workload from 180TB to 300). This is one of the advantages of either NAS or surveillance drives. They also tend to have more vibration protection (RV sensors, vibration firmware, etc.) as they're designed for NAS units where you could have many drives working in a small, enclosed space which could otherwise really disrupt and wear down each-other.
If you'd like to check it out, here is a short video on
choosing the right drive for the right application.
Thank you for considering Seagate, regardless of which drive you end up deciding is right for your needs!
