Seagate freeagent go DEAD?
Try disconnecting the drive and re-connecting it again.
Try a different USB port.
Try a different USB cable.
Try clicking populate and see what pops up.
You could try Recuva and see what it can find.
If you use Recuva you need to run the program from, and recover any files to, a different hard drive than the one you're recovering the files from.
None off those worked.
So ive taken it out of its caddy and have unpluged the usb2 adapter pcb and connected a sata cable to it. chkdisc and thats magic.
All the files seem to be there.
