Hi all,
I purchased two 160GB Seagate 7200.9 drives to go in my system recently. I installed Windows on the 1st HD, but hadn't tried to use the 2nd drive until now, and I'm having nothing but trouble with it
Basically I want to put Linux onto the spare HD for a dual-boot system, but I'm unable to partition it properly via windows or linux or anything else really.
Ok, the errors:
In Win2k SP4 (i have the 48bit patch thing applied), the first drive seems to be ok, but the 2nd one turns up the following error when running CHKDSK:
In Partition Magic 8, I get:
Using the Seagate tools:
Where C: is the drive with a working windows install, and D: is the problem drive.
I can't format or partition the drive using either the disk management software with windows, or with partition magic. I've not tried partitioning the C: drive yet as I don't want to lose my OS.
I've formatted, partitioned, and even done a low-level format (filled the whole drive with zeros) but none of these have fixed it. I can't install Windows or Linux onto the partition as they throw up errors. It is recognised in Windows when I format it as a whole drive and can have files stored on it, but nothing else.
Any ideas as to what I could do to fix it? Or any (free) programs that might be able to help?
Main system specs:
AMD Opteron 146
2GB Corsair ram
ASUS A8N32 mobo
Thanks to anyone sparing the time to help
Ok, the errors:
Code:
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Sorting index $O in file 24.
Index verification completed.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Insufficient disk space to correct errors
in index $SII of file 9.
Inserting an index entry with Id 256 into index $SDH of file 9.
Repairing an index entry with id 257 in index $SII of file 9.
Inserting an index entry with Id 257 into index $SDH of file 9.
Repairing an index entry with id 258 in index $SII of file 9.
Inserting an index entry with Id 258 into index $SDH of file 9.
Repairing an index entry with id 259 in index $SII of file 9.
Inserting an index entry with Id 259 into index $SDH of file 9.
Inserting an index entry with Id 260 into index $SDH of file 9.
Repairing an index entry with id 261 in index $SII of file 9.
Inserting an index entry with Id 261 into index $SDH of file 9.
Repairing an index entry with id 262 in index $SII of file 9.
Inserting an index entry with Id 262 into index $SDH of file 9.
Repairing an index entry with id 263 in index $SII of file 9.
Inserting an index entry with Id 263 into index $SDH of file 9.
Repairing an index entry with id 264 in index $SII of file 9.
Inserting an index entry with Id 264 into index $SDH of file 9.
Repairing an index entry with id 265 in index $SII of file 9.
Inserting an index entry with Id 265 into index $SDH of file 9.
Repairing an index entry with id 266 in index $SII of file 9.
Inserting an index entry with Id 266 into index $SDH of file 9.
Repairing an index entry with id 267 in index $SII of file 9.
Inserting an index entry with Id 267 into index $SDH of file 9.
Repairing an index entry with id 268 in index $SII of file 9.
Inserting an index entry with Id 268 into index $SDH of file 9.
Repairing the security file record segment.
Deleting an index entry with Id 257 from index $SDH of file 9.
Deleting an index entry with Id 259 from index $SDH of file 9.
Deleting an index entry with Id 258 from index $SDH of file 9.
Deleting an index entry with Id 261 from index $SDH of file 9.
Deleting an index entry with Id 262 from index $SDH of file 9.
Deleting an index entry with Id 264 from index $SDH of file 9.
Deleting an index entry with Id 265 from index $SDH of file 9.
Deleting an index entry with Id 266 from index $SDH of file 9.
Deleting an index entry with Id 267 from index $SDH of file 9.
Deleting an index entry with Id 268 from index $SDH of file 9.
Deleting an index entry with Id 260 from index $SDH of file 9.
Deleting an index entry with Id 263 from index $SDH of file 9.
Deleting an index entry with Id 256 from index $SDH of file 9.
Fixing mirror copy of the security descriptors data stream.
Security descriptor verification completed.
Correcting errors in the uppercase file.
Insufficient disk space to fix the uppercase file.
CHKDSK aborted.
Code:
Error #1627 Uppercase table incorrect, File 10 (128).
Code:
Results for volume C: (NTFS)
Volume Label:
Volume Size: 160.03 GB
Some files on the volume are open. This may effect the accuracy of the file system check and result in false errors.
The file system contains minor inconsistencies, these are not errors and should not cause problems.
Results for volume D: (NTFS)
Volume Label:
Volume Size: 160.04 GB
The file system contains errors that need to be repaired.
Main system specs:
AMD Opteron 146
2GB Corsair ram
ASUS A8N32 mobo
