Seagate RMA packing?
21 Nov 2006
Dublin
It says for a seagate RMA not to use bubble wrap or peanuts but to use 2" thick foam rubber. I'm finding this nearly impossible to get my hands on :confused:
What else could I use that will be sufficient?
Yeh I had the same issue with WD, I ended up putting the drive in bubble wrap and foam.
The ironic thing is when they sent the new one back it was in a box in a simple tray with no bubble wrap or foam, what gives!
bumping an old thread alert!
Any way, I have to rma a 3tb seagate and the pdf instructions say not to use bubble wrap but what's the deal...should i just wrap it up (including an anti-static) and send it on its merry way? Their packaging instructions are oddly specific and almost seem intended to just put people off!
