**SEAGATE SSHD STEAM VOUCHER PROMOTION**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
Seagate are running a promotion until the end of March where if you buy one of the selected drives below you will receive a Steam voucher of the value stated in the product title up to £15.
To claim the voucher all you need to do is click the link at the top of the product description and follow the instructions. The code are all linked to the serial number so makes sure you make a note before installing into your computer.
The Seagate 2TB SSHD will be landing today. (£10 Steam Voucher)
The Seagate 4TB SSHD will be landing Tuesday 15th. - (£15 Steam Voucher)
The Seagate 1TB Laptop SSHD is a brand new product and will be land Tuesday 15TH - (£10 Steam Voucher)
You can order now to guarantee your SSHD when they land here at OCUK.
Seagate Laptop SSHD 1TB 9.5mm 32GB NAND Flash Hard Drive £10 STEAM VOUCHER @ £89.99 inc VAT
Unparalleled Speed. Huge Capacity. Amazing Value.
- Equipped with 32GB NAND Flash for enhanced performance
- Boots and performs like an SSD
- Capacities up to 1TB
- All-in-one design for simplicity and ease of installation
- Installs and works just like a traditional hard drive in any laptop, PC, Mac or game console, and with any OS and application
- SATA 6Gb/s with NCQ for interface speed
- Self-Encrypting Drive (SED) versions available to maximize data protection and minimize the risk of confidential information breaches
- Backed by a 5-year limited warranty
Tests compared to previous model
- Game Load Test - 200% Faster/95% Faster
- Application Load Test - 600% Faster/400% Faster
- Windows 7 Boot Time - 35% Faster/25% Faster
Best-Fit Applications
- Thin, thinner and thinnest z-heights
- Perfect for gaming, creative professional, and high performance settings
- 9.5mm for all-in-one PCs and larger laptops
- 7mm for thin and light laptops and high-performance gaming systems
- Perfect for PS4 and Laptop Upgrades
- PS4 Compatible
Only £89.99 inc VAT.
ORDER NOW
Seagate SSHD 7200RPM 3.5" 2TB SATA 6Gb/s 64MB Cache - OEM £10 STEAM VOUCHER @ £76.99 inc VAT
SSHDs are now available for your desktop computer. Get the speed and kick of an integrated solid state drive (SSD) with the massive capacity of a desktop hard drive – all at a surprisingly low price!
SSHD technology uses the right amount of ultra-fast NAND flash (the same type used in SSDs) to increase system performance. Seagate’s Adaptive Memory ™ technology effectively identifies the most frequently-used data and stores it in the NAND flash. The results give you greatly improved boot times, application loads and overall system responsiveness.
SSHDs fuse the strength of SSD and HDD into one affordable and powerful device. You’ll be surprised at how little you have to pay to get SSD-like performance in your desktop system.
And since SSHD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
- Backwards compatible with SATA-II
- Capacity: 2TB
- Built in SSD type NAND MLC 8GB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Warranty: 3 Years
Only £76.99 inc VAT.
ORDER NOW
Seagate SSHD 5900RPM 3.5" 4TB SATA 6Gb/s 64MB Cache - OEM - £15 STEAM VOUCHER @ £124.99 inc VAT
- Capacity: 4TB
- Cache: 64MB
- Spin Speed: 5900RPM
- Warranty: 3 Years
Only £124.99 inc VAT.
ORDER NOW
I'm thinking about getting a hard drive to bung some games on and house my PC and Laptop images.
Would one of these be a better purchase than for instance a WD Black?
The Spin speed is a little low and with only 8GB of cache on a 4TB Hard drive seems a bit poor?
Hi,
The WD black will have the slight performance over the 4TB seagate drive but you will pay the extra £50 for the privilege.
The 4TB has 64MB Cache but uses and SSD type memory called MLC to boost the performance of the hard drive. The NAND MLC is basically what they use in some SSD's so Seagate have added this to the hard drives for the boost over a normal drive allowing faster boot times, install times and load times.
I am liking my first looks at the ..
Seagate Laptop SSHD 1TB 9.5mm 32GB NAND Flash Hard Drive £10 STEAM VOUCHER @ £89.99 inc VAT.
It is seriously time I replaced my old laptop harddrive!!
Questions...
Any ideas on what the max power draw (wattage) of these drives is?
I may be dumb, but I cannot find a USB Sata adapter connector on the OCuk website, such that I can do a clone transfer from a USB 2.0 enabled laptop. I am thinking I will need one that has an added power source to the connector...given the lower power output of USB 2.0. Do OCuk do such an adapter..or will they be sourcing one?
( maybe an idea for a bundle deal :D )
Questions...
The operating power is about 2.2w
This adapter should work for a 2.5' drive but a 3.5' drive you will need a power connector https://www.overclockers.co.uk/star...-adapter-cable-for-sata-drives-cb-164-ok.html
Thanks Robbie...not sure that answers my Question...but wont hog a promotion thread.
Regardless of offers I would not buy Seagate Hard drives. One of the most unreliable hard drive on the market. Just an opinion from my experience with Seagate hard drive products. I just use Tosihiba these days with out any problems.
We use seagate in all of our system builds so if they were as unreliable as you believe then we would be aware of the problem. We sell hundreds each month and the return rate is so low.
Opinion is not fact, one persons poor experience does not a bad product make.
That 1tb 2.5" drive is interesting Rob. Is it compatible with the PS4? 32GB SSD portion is pretty neat, considering people are still buying 32GB SSD's in the shop for boot drives. This gives you that (although I take it you have not direct control over the SSD portion again?), plus storage. I can see it selling well.
Doesn't have to be a boot drive but will work best as a boot drive as the OS files are relatively small and will stay in the cache.
As a games drive it won't be amazing as you'll only have a game or two cached and the rest you'll be pulling off the mechanical drive.
All of my mechanicals are Seagate. Just retired one which I bought from here in 1997!
@Shamus: I too have had a significant number of failed drives in PCs I've been asked to look at being Seagate. It's easy to assume this is because they are very unreliable but it's just as possible to say that they are/were the preferred supplier for many OEM PC manufacturers and hence greater numbers to start will give higher appearance of failure. Also, OEMs (clearly with the exception of OCUK :D) will tend to use the cheapest components possible. Cheap doesn't tend to equate to highest quality or durability.
And sometime 'stuff' just happens...sometimes repeatedly.
I can almost guarantee that seagate market share is bigger than WD for System integration.
Combine that with the price difference at the moment. I imagine you have a very likely chance these days of seeing seagate in 3 out of 4 machines
we've sold 30,000 1 tb seagate drives under code HD-257-SE the return rate is 1.4% that doesn't include returns direct to manufacturer but I'm pretty sure if they were really the problem some people claim we would know about it.
Toshiba has a 6% failure rate and WD 2.2% all on 1TB drives.
I can't tell you whether they were DOA or anything sadly but All in all none of them are shockingly bad.
