Hi guys
I had a friends Seagate External HDD here (SRD00F2) that contains a Seagate ST2000DM001 drive (the same model as sold here).
The drive wasn't purchased from OCUK and is still under Seagate warranty, but the data on it is important... Seagate state that the drive will be replaced under warranty, not repaired and offer no data transfer/recovery. The drive doesn't spin up or detect, when plugged into an external caddy I can see the power light dimming on the AC adaptor so I was 99% sure this drive has an IC board or drive motor problem.
OcUK kindly supplied me with part numbers and they are not quite identical and the FW version is different. As it was a very close match I bought one to swap the controller board to this faulty drive to attempt recover data/revive it.
Old 'faulty' drive:
New working drive:
According to the Seagate site this particular model of drive has several platter configurations, only through matching the model number, PN and FW are they compatible. I figured a £60 investment is the only option before discussing with my friend about sending it off for expensive (£300+) data recovery.
Swapping the board makes the old drive spin... But it is unrecognised by windows so I'm guessing the firmware isn't compatible with the older drive head. Anything else I can try before sending for recovery/replacement?
I've previously used Ontrack for recovery, but not for a number of years... Anyone else I should be going to in the UK?
Old 'faulty' drive:
MODEL: ST2000DM001
PN: 1CH164-571
FW: CC43
Date: 13163 Site: WU
New working drive:
MODEL: ST2000DM001
PN: 1CH164-510
FW: CC27
Date: 14194 Site: SU
