Searching solutions for very low sound in "new" pc build
25 Jan 2020
Previously, my mobo was an ASUS P8Z77-M, and i was using an ASUS Xonar DG sound card.
I got a "new" mobo, the ASUS PRIME B350-PLUS, but i can't use my Xonar because the PCI slot is blocked by the video card. So I'm using it's onboard card. U_U
Using the same headset, the Cooler Master MH751, the sound volume it's very low compared to before.
I configured all the volume controls that I know at 100%.
I can't decide what to do, because searching for opinions over the internet, most ppl say that o good external dac/amp would be miles better than any offboard card. And others say that offboard cards are better for gaming.
My focus is gaming btw...
not sure if asus has the same realtek dashboard as gigabyte...
set the headphone power to level 3 - basically a pseudo-amp
When I try to manually change to "Headphone", it shows a notification saying it's not a supported type.
it shouldn't matter i don't think... :confused: mine are connected to speakers but it still allows me to boost the audio with the pseudo-amp
sorry can't be of more help :(
