second drive slows boot??
9 Mar 2007
On a completely clean install to my ssd, windows boots in 8 seconds flat (3 to logon, 5 to desktop). If I then plug in my 2TB seagate data drive the boot time slows to 21 seconds (15 & 6).
I don't really understand where this slowdown is coming from, as there's nothing extra being loaded at all.
Any idea what causes this slowdown and how I can eliminate it?
Thanks.
I assume the system detects the HDD and has to wait for it to spin up before it can go any further.
If that's the case I don't see what can be done.
Sounds about right on my old desktop it would take longer for the bios to initialise all my drives etc than it would to boot into Windows!
Well, I downloaded the MS Performance Toolkit and ran a boot trace to see what was slowing things up, and it turns out autochk.exe was causing all the slowdown. Tried altering the settings so that it would ignore my storage drives, but it never made any difference. In the end I've just deleted the registry entry that executes it during boot, and now I'm back to booting to desktop in the times I'd expect from having my OS on SSD.
Info here
Just delete the value of the BootExecute key.
Info here
I'm glad you've managed to save those few seconds.
Make good use of them.
You do realise you'll lose any early warning of drive issues on your data drive now? Is that worth 13 seconds?
Obviously it must be.
I was going to warn him about turning it off but in the end I couldn't be bothered.
I just gave the OP the benefit of the doubt and assumed he knew what he was doing and the risks he was taking.
No doubt when he installs a few things like anti virus software and that adds another 2 seconds to the boot time he'll turn that off as well :rolleyes:
But you can find the time to be condescending?
It wasn't that I didn't have the time.
I just couldn't be bothered.
If you want to disable important checks to save a few seconds then that's your look out.
You know what the situation is now. You can choose to leave it or put the check back in place.
I knew the situation. If drives were shutdown improperly it will advise me that I might need to check the disk for errors. Since I'm the only person with access to my PC, I'm fairly certain that I'll know when it hasn't been shutdown properly, and I'm certainly capable of running chkdsk manually if required.
Again, thanks for the input and warnings, I do appreciate it.
