So, you'd like to think that this would be easy to do, but even under direction I've managed to screw it up
I logged into the wireless AP config, but there was no option for security settings. Ontop of this, the laptop user tells me it keeps picking up and losing the connection to the network now since I tried setting a password (see previous posts). I checked the settings and nothing had changed, still showing as an Open connection with no encryption.
There was a reset button in with wireless AP config so I hit that thinking it would return things to how they were before I started fiddling, but of course that wasn't the case. The laptop now picks up the AP, but with a different network name (Linksys_ses_58555) and says it's security enabled now with WPA, although I never changed any settings or entered a password for it to use etc. The Network Authentication settings on the laptop still show it as Open, not WPA, and it won't connect to the internet.
I can't seem to find a way to roll back any changes, to remove whatever settings are in place or to make it work more importantly.
In short: bugger.
.I logged into the wireless AP config, but there was no option for security settings. Ontop of this, the laptop user tells me it keeps picking up and losing the connection to the network now since I tried setting a password (see previous posts). I checked the settings and nothing had changed, still showing as an Open connection with no encryption.
In short: bugger.
