Hello, just recieved https://www.overclockers.co.uk/ocuk...rtx-4070-super-pre-built-gami-fs-pb04-ep.html
Would like to install the SSD from my old PC ontop of the one already in here. So wondering is a) https://www.amazon.co.uk/gp/product/B0CCN9QWKT compatible with the motherboard or...whatever it needs to be compatible with.
Then where and how do I connect it? On my old PC the cable management was non existent so it was pretty easy to find what was needed to just plug and now, however everything in this new one is very tight and tucked away and I really dont want to ruin 1.5k of PC by blundering around the day I get it. Pretty sure I can just take the motherboard? connection from the old PC and that hooks up just fine, its just the wider power? one I cant seem to find.
Any help would be really appreciated.
