i would say stick with p35 as it does almost everything x38 does except give 2 16x pcie slots in crossfire. its also a lot cheaper too
yeah just noticed the price difference, so which p35 would you go for?
happy building Jody![]()
If you want the x38 for overclocking and DDR3
Asus Maximus Extreme Intel X38 (Socket 775) PCI-Express DDR3 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-251-AS&groupid=701&catid=5&subcat=946
http://www.bit-tech.net/hardware/2007/11/22/asus_maximus_formula_and_extreme/1
http://www.ocworkbench.com/2007/asus/Maximus Extreme/g1.htm
The alternative x38 without DDR3 would be the Asus Maximus Formula Intel X38
http://www.overclockers.co.uk/showproduct.php?prodid=MB-253-AS&groupid=701&catid=5&subcat=946
Yeah thats the one i was looking at, i want to keep this comp for at least 3 yrs so this would be ok with ddr3 support, and from what ive been reading this is meant to be a good overclocker isnt it?
look at post #2, it almost fitted everything you origanally wanted and was just a tiny bit over you budget. post your final spec before you buy though
