Self Build help
29 Dec 2011
England
I'm planning on making my own pc some time in the next few months and was wondering if what I have put together so far is ok.
SSD 60GB (just for OS and drivers):
http://www.overclockers.co.uk/showproduct.php?prodid=HD-047-OC&groupid=701&catid=2104&subcat=
HDD 1TB 7200RPM:
Otherwebsite
Motherboard, Case and PSU (barebones):
http://www.overclockers.co.uk/showproduct.php?prodid=FS-278-OK
RAM 8GB DDR3 1333Mhz:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-023-OK&groupid=701&catid=8&subcat=
Optical drive 24x's DVD±RW:
http://www.overclockers.co.uk/showproduct.php?prodid=CD-112-LG&tool=3
Processor i5-2500k(possibly replacing this with ivybridge when it comes out):
http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN&groupid=701&catid=6&subcat=1275
Wireless card:
http://www.overclockers.co.uk/showproduct.php?prodid=NW-043-AS
Operating system W7 64bit:
http://www.overclockers.co.uk/showproduct.php?prodid=SW-127-MS&groupid=33&catid=1555&subcat=
I will be using the intergrated graphics until I can afford a dedicated graphics card.
I noticed with the barebones bundle I linked it comes with a 500W OCuk PSU, will that be enough for my setup?
You will soon be assailed by comments criticising generic, cheap PSUs.
And honestly, rightly so. They don't tend to put out the wattage they claim they do and are not overly reliable.
I'd say the wattage of the PSU depends on the GPU you'll get. A low end GPU will do fine with a 430W Corsair Builder Series, but if you're considering getting a mid-high end one, you want 500-600W just to be on the safe side.
I'd also say ditch the whole barebones because that motherboard is not going to like the 2500k, you're better of looking for a cheap Z68 board, like the Z68AP-D3 which is very popular due to its extremely good value/performance ratio.
Not sure how popular those OCUK RAM sticks are but for £5 more you could get these.
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £167.99
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT064M4SSD2) £87.98
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £81.38
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.98
OCZ ZS Series 650W '80 Plus Bronze' Power Supply £56.99
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT51264BA160A) £34.99
Cooler Master Elite 342 Case - Black £22.98
Edimax EW-7612PIN 300Mbps Wireless-N Network Adapter - PCI Express £18.98
LG GH22NS70 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
Sub Total : £471.89
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £96.73
Total : £580.37
SSD is better if your just going to be reading off it (OS and drivers).
Better motherboard.
Better PSU (you can go lower, but it will leave you headroom for GPU).
Better RAM.
If your just going to be upgrading to Ivy when its released, why not either buy the CPU second hand or an i3?
thanks guys I think Ill spend more on the PSU, motherboard and RAM as it isn't much more, and Id be getting a better package :D
