- 7 Aug 2003
- Bedfordshire
Lost my patience today...I even started looking at 5 year old Cars in protest!
I have an oil leak on my aging Corsa that seems to be coming from the bottom of the engine...although the sump plug seems very tight but this oil is literally caking the whole sump (excluding the back of it for some strange reason).
I've looked absolutely everywhere, top and bottom of the engine and it's bone dry, beside the sump, but I still suspect the sump plug although the lip of the sump seems quite flakey in rust so it could well be somewhere here. No need to check the big end bearings etc. because I don't get any noise from the bottom of the engine.
I'm going to get it up on ramps to find out whats going on. The plan is to drain the oil anyway (as it wanted a change anyway) and take the sump pan off, see if all is well on the edges and lip. I haven't lost a great deal of oil and the level is still over minimum.
My MoT expires in early August - and I thought it was September! I'd rather sort everything out before this though..
I'm also planning on tightening the Alternator and Power Steering belts (a horrible job on the <1999 1.7 Isuzu-engined Diesel Corsas) as my power steering belt is squeeling like something out of a horror movie on full right and left lock - power steering fluid level seems fine.
Luckily, brake hoses and ferrules appear in good shape and my bearings seem to be okay.
I dislike Brake work the most...brake fluid is horrible, nasty stuff but Mots always bring up things that you thought you had checked before.
