Greg said:Can I use Isoclene, its Isopropyl alcohol (99.7%) and some wipes that are used for Fibre Optic cables?!
^^Gord^^ said:Eclipse solution is 100% high purity methanol. I would expect isopropyl alcohol would be too strong to use.
I would strongly advice agaisnt doing that. At the end of the day, it doesnt show up on your images. I would again just try using the rocket blower upwards at the mirror and focus screen.Bolerus said:is eclipse and pec pads ok to use on the viewfinder (or watever you call the viewfinder bit that is actually inside the camera) I have a few bits on there, also looks like a little scratch as well
so, the second question is, are they replaceable, obviously anything on there doesent show up on photgraphs, but still nice to have them clear when you look through them
Greg said:alrighty, how bout the wipes? they suitable?
