29 Sep 2011 at 08:22 #1 Neil79 Neil79 Caporegime Joined 8 Sep 2006 Posts 39,609 Location On Ocuk Tamron A16 SP AF17-50mm F/2.8 XR Di II LD Aspherical (IF) - Canon Mount Trying to look for the serial number to send it back for replacement, is the serial number this one on the lens itself and not on the box 9563xx
29 Sep 2011 at 08:37 #2 Alpherah Alpherah Soldato Joined 24 Jun 2008 Posts 8,328 I believe it should be the number on the lens (normally towards the 'tripod hole' on bigger lenses, not sure on smaller ones). Although Tamron for rebates ask for the serial number on the box itself :x Cant you just include both? Or is it some kind of online form you need to fill in.
29 Sep 2011 at 12:03 #3 Neil79 Neil79 Caporegime OP Joined 8 Sep 2006 Posts 39,609 Location On Ocuk I saw a serial number on the lens which is in op, used that for the RMA form. Thanks Alpherah
