Serious advice ASAP
6 Jan 2012
Hello ive been building my own rig for the past 3 months, back in october i bought the CPU, motherboard, case, and PSU.
yesterday i ordered my 7970, ram, etc.
Now basically ive spent all evening putting it together used the popular guide on youtube,
and basically its like my motherboard is dead?
Ive tried turning the pc on with gpu ssd drive and everything connected but the pc makes no response, no fans start no lights.. nothing.
I tried taking the motherboard out of the case and put it on the box and and just connected the 24 pin connection and 8 pin supplementary cpu power and still nothing happens, no fans or anything.
Now im pretty much panicking here cause ive spent over £1200 on this rig and i don't know what to do now.
ive tried testing the PSU on my old rig and the psu works fine.
whats everyones advice?
a friend of mine told me the motherboard may have been DOA?
if thats the case thats puts me in a bad position because i got the motherboard back in october but only opened it today
whats overclockers returns policies?
Im so upset about this because ive waited so long to finally get the rig up and running and now this has happened.
Thanks in advance for any advice given.
First, calm down!
You've probably done nothing wrong, in any case the motherboard is still under warranty.
Just makes sure that everything is switched on and is where it is supposed to be. Are we sure that the fuse has not blown on the plug?
As above, sit down with a tea/beer and relax a bit.
Then go over everything in a logical order, make sure everything is plugged in where it should be and the plugs are in properly.
Possibly unplug everything you dont need, case fans, dvd drive etc and try again.
Will either be something silly or something dead.
Call OcUK in the morning if you suspect something is dead, they dont bite!
:p
http://s10.photobucket.com/albums/a146/Sinerster/?action=view&current=IMG00202-20120110-2143.jpg
http://s10.photobucket.com/albums/a146/Sinerster/?action=view&current=IMG00200-20120110-2143.jpg
i tried just connecting the 24 pin and 8 pin cpu, and still nothing.
if its under warranty how long do you guys think it would take to get a replacement?
its so frustrating cause ive waited over 3 months. and was really looking forward to trying out some games with my 7970 tonight.
the rig currently has the motherboard ram and cpu and cooler on it. but is outside of the case,
Since as it will not be running for for a while and the motherboard will probably have to get replaced, should i dissemble the cpu, and fan and put the components back in their boxes. or should i put everything back in the case and leave everything in there until ive sorted out the motherboard replacement?
Usual one is no power cable to your cpu - check your motherboard manual and make sure all the cables to the mb are correct.
If it is a modular power supply make sure they are all pushed home.
It is frustrating - been there done that - best of luck.
have you made sure the front panel connectors are seated correctly? when everything is connected is there a green light on the mobo? list the complete spec of the system please :)
Is there a power switch on the PSU?
Is it on at the wall?
Try with one stick of RAM, disconnect the drives as you dont need them to post and get into the BIOS.
You did plug both power connectors into the 7970?
and yeah my brand new monitor is connected to the same wall socket and thats powering on.
ive literally got no lights on the motherboard when the psu is connected, the PSU does not do anything when connected to the rig no fans spinning or anything.
i5 2500k
8gb corsair ram 2x4
60 gb SSD
160 gb hard drive
msi p67a-c45
xfx 550
gpu 7970
wow guys guess what i just tried removing the ram than i tried shorting the power pins with a screwdriver and it came on, im going to try putting everything back in the case but this time make sure i put the power on, power led wires on properly.
all those little cables that run from the front buttons on the case into the mother board...
remove all of those
remove all HDD's, CD ROMS.. everything except RAM, CPU, Power
now.. those little cables that unplugged ... one of them will be for power, find a flat head screw drive and briefly join the two pins together (manual switch)
if you still dont get anything, not even fans spinning up etc then yeah mobo probably dead
does the psu have 2 x 8 pin mobo connectors
sometimes 1 x 8 pin and 1 x 4+4 pin?
if so make sure you have used the 4+4 pin, the other one is for high end overclocking boards for extra stability
