Seriously high RAM usage with nothing running
14 Nov 2012
Chesterfield
Spec:
4790k @ 4.6ghz
8GB Kingston Savage @ 2133
GB Gaming 5-MX
2x GTX Titans SLi
I've seen this for a while now, I've got Chrome open with about 8 tabs and my RAM usage is about 95%. Playing BF3/4/Hardline/Dying Light are quite rightly grinding the system to a halt with 7.8GB being used.
Any reason for this? CCleaner has been run, Malaware Bytes is showing nothing. I've also got about 6GB allocated to the page file, I've not set this.
Is this common running dual GPUs?
Have I missed something?
Windows have a memory leak?
If you are referring to Killer Network Manager, than yes! Would this be the issue?
Almost certainly,its a known issue on win8.1 i suffered from it too and took me weeks to figure it out
Heres what you need to do for a fix
Open Regedit as admin and find the following library
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Ndu\
then select the 'Start' entry and change it to 4
Then restart your PC :)
Thanks!
I've made the change and restarted, will see how it goes!
