- 7 Aug 2004
Hey all, just got:
E2140 CPU
120 Extreme 6pipe heatsink
Gigabyte GA_P35C_DS3R (Socket 775) F1 Bios
8800GTX BFG OC
4GB 2x2 OCZ
700WATT FSP PSU
It worked fine while installing vista, then had it on for an hour, switched off........30mins after switching off it now wont start, it either:
1) Always comes on for 2 seconds then cuts out
2) As above, but then fans start spinning again a couple seconds after it cuts out, then cuts out again
3) Occasionally I get a highish pitched 'eeeee ....eeeeee....eeeeeee' from I *think* the graphics card, but I cant be sure, is from something, then it again cuts out,
I have to unplug it from the wall for 15 seconds then try again but the above always happens, if i try the switch while still plugged in nothing happens in the 1st place.
have tried it with just the bare essentails, and the above keeps happening, whats going on ? short out ? PSU had it ? HELP !![Frown :( :(](/styles/default/xenforo/vbSmilies/Normal/frown.gif)
E2140 CPU
8800GTX BFG OC
4GB 2x2 OCZ
700WATT FSP PSU
