I have a server with 9 internal HDDs inside. It used to reside in a cupboard and the low amount of noise it made wasn't audible, which was fine. However, it's now located about a metre from the sofa and the constant whir is very annoying.
I can't even figure out where the noise is coming from. I've tried unplugging both case fans and the CPU fan, yet it still makes pretty much the same whir. As far as I can tell, this only leaves the PSU fan and the HDDs. The HDDs are set to spin down when not in use (and it does take 10 seconds or so when accessing a network share for the first time as the HDDs spin up), so I'm confused as to how it could be those.
I've had experience before where the PSU fan was the loudest fan in the system, which is annoying because quality, quiet PSUs with decent power are expensive. The only other thing I can think of is to replace the fairly cheap case with a quality, silence-oriented one with soundproofing. However, these are also expensive, considering I need one with at least 3 5.25" bays (for my 3-5.25"-to-4-3.5" caddy).
I've even considered buying some soundproof foam and basically making a cover for the shelf the PC is on, but this may not help and would require some DIY which I can't really be bothered to do. Maybe I should swap out the PSU (not a quick task) and see what happens? If that doesn't help then maybe a new case is the best solution.
Anyone have experience with this?
