Setting curve for CLC pump speed
18 Oct 2002
Devon
I have just come into possession of a BeQuiet Silent Loop 240 and am pretty impressed with the results given this is my first departure from air cooling as it has knocked about 12% off my temps at both idle and load coming from a Thermalright HR-02 Macho.
Due to current circumstances I am having to have my base unit on my desk about 2ft away from my ears so I can just about hear the pump at 100% (2200rpm), whilst I have the fans running low enough to be silent (650rpm). The pump is silent at 60% (1600rpm) so I would like to have it on a profile that keeps it at the silent speed whilst the CPU is idle (<35c) but that switches it to 100% when the CPU starts working (>35c).
Does anyone have any comments on whether this would cause any issues in terms of the coolers operation, or would it be better to leave it at 100% and just put up with the slight noise which I will probably get used to. I guess I'm concerned about whether the motor is OK to have its power regulated in this way or if this will damage it.
My H105 runs at about 1800rpm pump speed fixed all the time, never had the need to increase it, it's silent and temps are very good.
