setting Geil ULL
30 Dec 2007
Bexleyheath, Kent
HI all
I have tried to set the ram as it states (4-4-4-12 @ 2.1v) but everytime I manually set it the computer locks up and wont start up correctly, does anyone have any ideas what I am doing wrong??
Set up as per sig, and as yet no OC done just wish to have mem set right first
Is the memory multiplier set to x3.0, and the memory overvoltage set to +0.3v?
It should be in the MIT menu with the other overclocking options (press Enter on the option and go up and down the sub-menu to find x3.0).
Thanks Cob I will give this a go and will let you know if this works or not. :D
THANKS COB ;)
I have just done it and everything works, is there any tests that I should do, now mem is working as it should be.....memtest perhaps :confused:
In CPUZ under FSB/DRAM it is 2:3 is this correct or should I also change this??? If so where abouts in BIOS should I be looking. Sorry for all the questions but getting excited as this is my first build and would like to OC and see how far I can get, but at the moment my temps are too high (CPU) in comparison to others, looking at upgrading HSF, but getting mem set up correctly is a bonus and a learning curve.
