i want use my server to dish out ips instead of my router so i can use microsoft isa. but everytime i try to do this it does not work. when i try to change gateway my server ip it does not do anything. does anyone have any guides for me?
Freakish_05 said:If you have the following setup:
Internet -> Server -> Lan
Then set the IP address to 127.0.0.1 (localhost). Failing that try the IP address of the server (would be something like 192.168.0.1 or 10.0.0.1 as it is the DHCP server)
etc
HTH
doran1801 said:that was the impression i got from reading it up. so if i set my ip address on one of the net cards in the server to say 192.168.1.10 and then make sure dhcp is turned off in the router it should work fine and assign the client an ip from the pool i have set? only other questions are a do i set the router to dhcp relay, or disable it altogether. and i have to net cards in the server what is the best way to configure them?
doran1801 said:so am i correct in thinking that one net card should have a static ip with the gateway of the router still am my ip dns servers for internet access and the other should point back at itself being the dhcp server?
doran1801 said:i have an adsl connection The only reason i am using isa is because it was the 1st one that came to mind. i have 1 nic set to static and pointing at my router and isp's dns but what do i do with the other one?
doran1801 said:i also have a bt home hub router which i could use as the internet connection to the sever. So if i set that up 1st then use the lnksys to create a lan network linking server to clients?
