Setting up a new PC with two drives
3 May 2013
Stockport
Hi guy, just got a shiney new custom build PC from overclockers
And need some advice before I balls it up
My primary drive is a Samsung 120 SSD With a 1tb secondary drive
So far I have installed windows 7 ultimate and Origin with BF3 on the primary drive
Everything wants to install on the primary drive so I have stop trying to install anything else till I have a clue what I am doing as the 120 storage will disappear fast.
Thanks in advance
If the 1tb drive has been formatted etc and is available with its own drive letter then just pick that drive when you're installing stuff.
As easy as that lol I feel daft asking but was concerned at the rate that it ate in to the 120 SSD,with all the windows updates will I lose my 120 rapidly?
And have I done the right thing putting the OS ON My SSD?
Yes you have,windows does go on the ssd :)
Dont worry about space,you should be fine with a 120gb ssd for windows and a few games.
These is a way to get software to automatically pick the 1TB drive to install.
However its a bit of a pain to set up if you don't know what your doing. so as said above, when installing just change the drive.
