I have got actve directory domain services installed on the server and its working fine. Just trying to set up MS Exchange now. but theres plenty of guides on how to do it.
thanks for the help (some of you ) :>
Basically, you have:
Router:
Internal IP - 192.168.0.1
External IP (Static IP/One from ISP): 4.2.2.1
Server:
IP - 192.168.0.2
Now in this example you want to set up a web server, so anyone going to 4.2.2.1 gets to the web server on your server in your house (192.168.0.2).
To do this, on your router, you need to set up port forwarding so that TCP port 80 is forwarded to 192.168.0.2:80 (Port 80 on 192.168.0.2). Your router will then use Network Address Translation/Port Forwarding to pass through the traffic from the outside to the inside while tracking the TCP connection to keep it alive.
HTH.
Even if you do set-up exchange, it's likely that you won't be able to send to a lot of places, as residential IP ranges are often blacklisted for email.
I wonder if you can round this though but using a pay-for SMTP relay?
Talk about throwing yourself in at the deep end!
How are you connecting externally, do you have a static (external) IP, or are you using a dynamic DNS service?
are you going to share data on the server too?
Regards Sam
i have an external ip address ye, that i bought from my ISP
To all the folk saying that setting up AD/ Exchange is too complex - WTF? It's an absolute doddle. Anyone who can read, and has the ability to use google on any messages that seem confusing can set up a home domain.
The dude already seems to be doing fine.... complex my arse![]()
