Setting up a water loop
26 Nov 2003
East Sussex
I am going to be cooling my gfx soon, all the bits are in the mail.
I have ordered some "Ice coolant", which is apparently a water replacement. 32oz, will that be enough for a small setup with a 250ml res?
I wish they'd keep one measure instead of confusing me :p
Should I set the whole thing up in the bath or some such until it seems ok then attach to the card and install in PC?
32 US fluid ounces = 946.35295 ml
So, just under a litre, so you should be ok with that. You can always top it up with de-ionised water from the garage if you find you need more, or have any spillage!! :)
I bought 5 litres of de ionised water from Halfords for £3
Added 1/2 litre of nice blue antifreeze and job done.
Running with a Swiftech Apogee GTX waterblock
