Setting up domian with gmail interface
You need access to DNS control over your domain so you can create the MX records Google Apps need. You will then need to upload a simple text file to your root directory for Google authorisation.
Hmmmmm, and I thought I knew about PC's. Fancy doing it for me, or explaining it in more depth?
Apologies, hadn't taken the time to read your other thread. Still slightly baffled as to which stage you're at, do you not know the login details for the apps account?
Beyond that, looks like you've still to setup mx records for it although that's easy enough with 123-reg.
Thanks for your time, hopefully I can sort this out :)
Ere, dont know my login details :confused:
Ive not setup mx records yet.
What do I put in the boxes? My hotmail email in 'Forward to' but what about user? Do I need to tick 'return to sender'?
If you're unsure what's before the "@mejimwhite.co.uk", use a catch-all instead. Check number 4, "Forward mail sent to unknown users to the email address" and put your hotmail address in the box below.
Thanks done, now whats the next stage?
