Man of Honour
- 18 Oct 2002
You should try to find out why people are having problems with installing it on Redhat 8, since it might be it that other distros use the same thing that the modem doesn't agree with. You try something like Slackware or Gentoo if you like
... if it's something to do with the kernel ... you can try it with a vanilla kernel to see if it works.
whats slackware like?
i have an ethernet adsl modem but its the 2nd cack one ive received (cant ping it) so it going back (again) 3rd time luck hopefully, then i wont have to worry about the modem drivers. As for gentoo, where do i store the tarballs if i download them from windows? if i put them on cd how to i copy them to the hdd from the gentoo command line thing?
