setting up netgear dg834g without installation cd
1 May 2007
I must apologise in advance if this problem seems unworthy of a posting here, but never the less i am at a loss with what to do next.
I bought the netgear dg834g v3 on ebay from someone selling off their freebie from aol. My internet provider is talktalk. I tried to input my user name and password through the aol installation software and actually got it onto the router, but the process was interupted when the inevitable check with aol caused an incorrect username input (ending in talktalk.net).
So the question is can i access the router in another way that can allow me to correctly input the username, password, 13 digit key etc, without having to use an installation cd. (the one that came with my talktalk is only geared up for use with one of their modems).
Great if someone can help!
The manual should tell you the router's default IP. Stick it into your browser. Ta daa.
Alternatively, if the machine you're using got an IP automatically from the router, the default gateway it was given should be the router's IP.
The CD's just a (poor) wrapper for the web interface.
Welcome to the forums. :)
You can reset it back to factory defaults with the reset back to factory settings switch (which will be shown on the sticker on the base), Just push it in for about 10 secs or so with a paperclip, then just log into the routers settings with your broswer, the http://192.0.... and then select yes for the Auto Connection Setup, then hit next, then off it goes setting itself up, then in about 5-10 seconds or so it will ask for your talk talk username/password, enter them then use the test button to make sure it connects successfully, if so then hit Apply and jobs a good'un.
or you could just log straight into the settings and select the setup wizard at the top left, there you will find the Auto Connection Setup, so you can do as above, select yes etc....
You may actually have to go through the reset back to factory settings, as the previous owner may have changed the settings password so you won't be able to access them, if so once reset the default ones are admin/password, but all the info is on the sticker on the base.
hi loadsamoney, havent been able to try the router configuration yet, but just wondered if i could ask you about another problem thats been bugging me a little lately.
Occasionally when i turn on my computer, it gets to the choose user screen (xp home edition i think) but then wont let me select a user. The mouse pointer still moves but wont activate button, cant do it using the keyboard either. Im gonna remove other users soon anyway, but just wondered if this is something to worry about? The only way out of this when it happens is to reset the computer. Im just worried that one day i reset the computer and it will still be the same!
cheers!
cheers!
Not sure, ive never heard of that before sorry.
Thanks for the info on setting up the router, i was able to connect to it using the ethernet cable and input my username and password for my talktalk account. However when i then try to gain access to the internet, i am automatically directed to a talktalk webpage which informs me that you do not recognise the username and password given. Even though i know these work cos i used them successfully using the wired broadband modem i have been using up till now. I think it is something to do with no having used the setup cd from talktalk whereby you are asked (if you are not using one of the routers sent with talktalk) to input the username and password using whatever software before running the talktalk setup cd again. Here a check is carried out to 'detect' the router being used, but each time the test is run it cannot find my router, even though i input everything it needs. What should i do next?!!
All i can think of is you may be inputting the username/password wrong as it should connect.
Have you done the Automatic setup, so the router sets itself up.
Yes i first did the automatic setup and stored my username and password. After when it didnt work i did it all manually too. I know it should work the username and passwords i gave are correct and yet whenever i access the internet throught the router i am automatically redirected to a talktalk screen saying they do not recognise the username and password. They seem to make a big thing about having to use 'their' modems and routers, and that if any problem should arise with another router you choose to use they will not help. Im starting to wonder if ANY other router rather than the one you have to buy through them will work. The username and password i am using with the routher is no different from the one i have been using with my wired router. The wired router was a tiscali one, but when i input the username and password it worked first time.
On this router dont you need to flash it first with different firmware? It comes with an adapted firmware. Put the lastest retail firmware on should be fine. Download it from Netgear.
I did this with my free SKY router.
sorry for jumping in on this thread but ive got the netgear 834v2 and wanted to move over to vista but netgear are not supporting the version 2 now in vista, could i still get it to work on vista or do i need another router thanks and sorry for jumping in
thanks tolien so its a case of following what was said in this thread and it should be ok,p.s i will have to reset it first though wont i as its been running on xp pro
