Hi everyone,
I am in need for extra storage and I have two laptops that I have pulled the hard drives out. They are 250GB Crucial SSD's, identical models. The laptops themselves were throwaways, I will not be buying additional storage. I'd like to set them up as RAID 0 as I do not need the redundancy, just fast access to the max capacity of the volumes.
My motherboard is the [Asus M5A99X EVO R2.0] - manual link below
https://images10.newegg.com/UploadF...nce/ASUS/E7428_M5A99X_EVO_R21452966656285.pdf
[Current SATA Configuration]
SATA1: 500GB SSD (OS)
SATA2: -----------
SATA3: 1TB HD (Secondary Storage)
SATA4: -----------
SATA5: -----------
SATA6: -----------
I also have a 500GB NVMe m.2 plugged into my PCI-E port using an adapter and 4TB USB External HD as my primary backup device.
I have never configured a RAID array before and would like to set one up on my machine however theres a few things I am confused about. It says in my manual that ports 1-4 and 5-6 are grouped together. Currently they are both set to AHCI. The groups can be confiured as follows
q1) If I change ports 1-4 to RAID do all 4 drives need to be set up as RAID devices?
q2) Can I move my 1TB to say port 2 and have ports 3 & 4 set up as RAID?
q3) Can i set ports1-4 to raid, have my raid set up on 1&2, and have my OS and Secondary as 5-6 on IDE? - Is IDE going to give me any disadvantages to how it currently operates on AHCI?
q4) Will moving a hard drive to a new SATA port change the drive letters and consequently cause problems with anything that has paths set up between my drives (SATA and PCI-E)?
I did try to change all ports to RAID type and load my OS but it got into a boot loop and didnt work. WHen i changed it back to AHCI it gave me some startup repair messages that gave me a little scare but its working fine now.
When I initialized the ports to RAID it did give me a RAID config option during boot but I did not know what I should be looking for to allow the OS SSD to load properly. I did read that RAID has the same benefits as AHCI so thought i was able to run the PC in that config fine.
Thanks for reading, any help is appreciated.
SATA2: -----------
SATA4: -----------
SATA5: -----------
SATA6: -----------
- if [Port1-4 -> AHCI] -> [Port5-6 -> AHCI or IDE]
- if [Port1-4 -> RAID] -> [Port5-6 -> RAID or IDE]
- if [Port1-4 -> IDE] -> [Port5-6 -> IDE]
