Setting up Samsung 830
30 May 2012
Bristol
I've just ordered a Samsung 830 128Gb and was wondering what the best way to set it up was. Obviously I will be using one of the Sata 6Gb/s ports, but would it be best to use of of the ones running off the Intel chipset or the AS Media controller? Also, I'm planning on unplugging my old drives, then simply reinstalling windows onto the SSD (AHCI mode right?). Will I need to reinstall all the drivers as well? I've got a 7950 on the way, and decided it would be nice to install it on a new install of Windows. I'm assuming that documents and games on my current HDD will still work fine on the new install? Thanks :)
EDIT: Also, would using Norton Ghost instead be a better idea?
Intel.
AHCI mode right?
Yes.
Yes as you're doing a fresh Windows installation.
Documents yes, games I doubt it as it'll mess up the installation.
I'll leave it to someone else to advise about cloning as I've never had to do it.
Intel Chipset.
Yes that is fine, you will also need to reinstall all the drivers, I would download all the latest ones.
Documents will work fine, not sure about games, you can always transfer saved game profiles over as that is all I did, check google. I woudn't bother using Norton Ghost, I didn't.
yeah sell ghost instead, apparently it fetches quite a bit. some games work, some games don't - i find it best to start fresh and transfer just saves as nelly says
I was just wondering with regards to cloning the OS from my current hard drive to the SSD: if I cloned the OS to the SSD and left everything else behind, would all my drivers/games work fine if I boot from the SSD? If so, would I delete the windows folder off my current hard drive or leave it on there? Thanks :)
Backup your documents, settings, save games etc then do a clean install on the SSD.
Ghost clones entire partitions/disks not the individuals folders. You can't just clone the Windows folder over and hope to that your applications and games will run off the hard drive. It'll break all sorts of stuff behind the scenes in Windows.
Yep.
It's somewhat easier nowadays as most things live in the Users folder and look at the Libraries. The days of hunting down savegame files in obscure directories and backing up .ini files are pretty much gone.
Yep.
Ahh ok, so pretty much the Users folder is all I have to worry about. If not, replaying games is no real hardship I suppose. Reinstalling drivers and games will be a bit time consuming, but hopefully the faster boot times will make up for it :p
I physically fitted the SSD and installed Windows 7, SP1 and all the drivers in about 40 minutes the other week. Took longer to install a couple of games from DVD.
Yeah.
Technically the driver itself will install into the Windows folder - you don't get an option. If there are applications/utilities that come with the installer then you may get the options to chose the location. Nothing wrong with putting them in the usual Program Files folder.
So would it be best to back up my users file and then format my HDD, then just reinstall windows onto the SSD? Would I make a programs folder on both the SSD and HDD so I can decide which games to install on the HDD and SSD?
When I reinstall Windows onto the SSD and format the HDD (after backing up users folder) where would all the program files folders and users etc. be? Would they also be on the SSD? I'm assuming Windows makes the folders automatically when installing, so could I simply move everything other than the windows folder to the formatted HDD, leaving just the windows folder on the SSD?
